That works really well! Thank you. I just have a problem with automating the text...
The script looks at the values that are filled in the scene director when formatting, and not at the values that are current in the sequenser.
When I format the items and link a data link, it is automatically filled with results. I place this item in the sequenser, so it is included in the group.
But if during the view, it appears that no information more available is, trough datalinq, then it will be displayed. That's because the script looks at the values in original state. Even if I have checked "return empty" via datalinq.
I also tried to link datalinq, last way via the sequenser, but this produces the same result...
Datalinq seems to retrieve the information later than your script performs the check.
