  • 1.  Clip Server Key/Fill timing off
    Posted 09-21-2020 14:00
    When running a wipe out of our Clip Server channel the key and fill are off by a few frames, they run fine out of FRamebuffer 1 and 2, any way to fix this?
  • 2.  RE: Clip Server Key/Fill timing off
    Posted 09-21-2020 14:03
    What switcher do you have?? I recommend checking for frame syncs that are being applied to the fill and not the key.
  • 3.  RE: Clip Server Key/Fill timing off
    Posted 09-21-2020 14:06
    Carbonite, no FS set on any of the Xpression channels.
