  • 1.  Eject Clip(player)
    Posted 01-13-2021 17:55
    Is there a Rosstalk command to eject a clip in the XPression Clip player? CLFB 0001 does not work when the FB is a Server Channel. CLRA does work, but it clears all FBs (obviously).
  • 2.  RE: Eject Clip(player)
    Posted 01-28-2021 14:31
    You can put a script action Keyboard / GPI Mapping and keybind that to something like "ctrl+1"
    'Then place this script in there, 0 will clear Channel 1, 1 will clear channel 2.
    dim SC as xpServerChannel
    Engine.GetServerChannel(0, SC)
    sc.Eject()
    'this script will remove the clip from the preview on the server channel.
    sc.EjectPreview()
