  • 1.  Displaying OT on scorebug using Datalinq
    Posted 01-25-2021 14:19
    So I have a Visual Logic script made for displaying 1st, 2nd, 3rd for our Scorebug. (see picture)
    The String values are 1st, 2nd & 3rd to replace the Datalinq 1, 2 & 3 for the bug.
    The problem I run into is when the Datalinq reads OT, the graphic goes blank.
    I cannot even take the text field and make it Static and change it to OT, it just stays blank.
    Any ideas?
  • 2.  RE: Displaying OT on scorebug using Datalinq
    Posted 01-26-2021 16:51
    Does the Datalinq block pass "OT" or just nothing an empty filed?
  • 3.  RE: Displaying OT on scorebug using Datalinq
    Posted 01-26-2021 17:11
    I can see the "OT" show up on the Datalinq field, but I think because of how I have it set up on this visual logic, it is not passing to the text field.
    Trying to find a work around because I want to keep the 1st, 2nd & 3rd text with the visual logic I have set up, but want to also have OT show up when they go to overtime.
    Right now it just comes out blank.
  • 4.  RE: Displaying OT on scorebug using Datalinq
    Posted 01-26-2021 17:22
    That's because the input selector can only accept integers.
    What I suggest is adding some VL before such as a compare block and if that equals OT then pass "4" and then connect a value you want in that 4th position otherwise pass the number value.
    Does that make sense, I can make an example if a bit if you like?
  • 5.  RE: Displaying OT on scorebug using Datalinq
    Posted 01-26-2021 17:23
    Simon, if you can show me visually, that would help alot!
    Thank you!
  • 6.  RE: Displaying OT on scorebug using Datalinq
    Posted 01-26-2021 17:47
    So for me this works. I am using a text field in place of datalinq to make things easier for testing.
    In my example 1 passes 1, 2 passes 2, 3 passes 3 and OT passes OT, anything else is blank.
