  • 1.  No alpha channel on Datalinq image material
    Posted 01-17-2021 23:49
    Is there a reason when I datalinq the below image to a material that there is no alpha. Just a black background.
    https://rugbyimages.statsperform.com/Player%20Bodyshots/111/2020/500001/Manu%2CJoeseph-2020_H_0377-body-shot.png
    I am able to download the image and create a new material and the alpha works but for some reason there is no alpha channel when datalinqing
  • 2.  RE: No alpha channel on Datalinq image material
    Posted 01-20-2021 16:50
    I was able to get an alpha channel when I tried it.  You may want to check that you are running the latest software build; incase this was a bug in older versions.
  • 3.  RE: No alpha channel on Datalinq image material
    Posted 01-20-2021 23:18
    Thanks Brian good to know it works for you however I'm still having no luck.
    I have updated recently so I'm on build 5250
