My proposal:
- Create a text object and publish just this text object
- Create a text object and use it as a delimiter (double space or so)
- Create a text object and in Visual logic Concatenate first 2 text object and then concatenate it again 10 times or more in order to have enough text as 2 times width size.
- Create a new Scene Director just for the crawl job
- Create a quad and animate it and use it as a crawl leader, add an event to loop this scene - at the half of the text the scene will jump at the beginning of the text
- Divide final text width by 2 and multiply with quad move (from 0 to 1) and invers it to change the direction
- In the main scene director add a trigger to start the crawl text
- The crawl will start in sequence mode, where you cand change the text too
Check my example here: http://s.go.ro/ryxxnxwi | password: 805214
Have FUN!
Gabriel
