  • 1.  TeamViewer from Mac into XPression - Fast Recall doesn't work
    Posted 11-24-2020 21:11
    Due to COVID-19, we have a graphics operator working remotely and using TeamViewer to remote desktop into the XPression machine. All is well except the operator cannot use Fast Recall. It's enabled, but pressing keys on the NumPad of the remote computer doesn't initiate a Fast Recall.
    The remote operator is on a Mac, and we're wondering if that's something to do with it? If we try the same exact configuration with a PC on the remote end, it works fine.
    Does anyone have any thoughts?
  • 2.  RE: TeamViewer from Mac into XPression - Fast Recall doesn't work
    Posted 12-02-2020 19:37
    I believe this issue was resolved after contacting Tech Support and was fixed by making some edits to the XPression Keyboard Map.
    XPression > Edit > Keyboard Map
  • 3.  RE: TeamViewer from Mac into XPression - Fast Recall doesn't work
    Posted 12-03-2020 15:43
    <x-zendesk-user data-user-name="Garner Millward">369642218431</x-zendesk-user> -- Unfortunately, no, Tech Support didn't have any suggestions for us. Can you elaborate on the Keyboard Map option you mentioned?? Thanks, Brian
  • 4.  RE: TeamViewer from Mac into XPression - Fast Recall doesn't work
    Posted 12-09-2020 22:56
  • 5.  RE: TeamViewer from Mac into XPression - Fast Recall doesn't work
    Posted 08-25-2022 10:24
    This seems to be an issue with TeamViewer in MacOS that it sends "numpad 1" as just "key 1" to Windows over the remote connection so XPression does not receive the correct keys for fast recall.
    To bypass TeamViewer's bug, you could try running TeamViewer Webclient in Safari. Their web client seems to send the correct keys for Fast Recall to work.
    Billy Cheung
