  • 1.  Images sequence encoding
    Posted 02-11-2021 15:20
    Hello there,
    We have a PNG images sequence we would have to deliver to Xpression on very regular basis (twice a day, actually).
    Playing the sequence directly is not a suitable option, as Xpression goes very loaded and slow. So we have to transcode to video.
    In order to automate this job, here are a few questions:
    * I'm very surprised to see that Xpression is not able to import .mp4 H264 files as Material. Is it related to QuickTime installation?
    * Is Xpression Codec available in scriptable apps like FFMPEG or Telestream Vantage?
    * Alternatively, is Xpression Video Coder software able to be controled through command lines? So I would write a batch file.
    Thank you very much for your feedback,
    Julien
  • 2.  RE: Images sequence encoding
    Posted 02-13-2021 12:51
    Some more info: so far, I've been able to encode the images into a .avi file Xpression is OK to import :
    ffmpeg -y -framerate 10 -i c:\test\sat%02d.png -codec mjpeg -r 25 c:\test\satellite_mjpeg.avi
    But performance is soooooo poor, although it's just a 8 Mb MJPEG file!
  • 3.  RE: Images sequence encoding
    Posted 02-15-2021 10:40
    We have the Xpression codec running on our Vantage farm. There's a separate installer available through the support channels.
  • 4.  RE: Images sequence encoding
    Posted 02-15-2021 11:55
    Thanks Adam, I guess this is the best way to go. I'll get in touch with the support team.
