Like i said, as far as i'm aware, Visual Logic
only runs when a scene is online, so when a scene is in preview, the scene is not online and Visual Logic would not run at all. Therefor the node would not be called upon and give no output, no online of offline boolean.
Or am i wrong here and does Visual Logic run even when the scene is not online?
Justus van der Hulst
_____________________________
Live Graphics Operator
United Broadcast - Euro Media Group
Hilversum, The Netherlands
Sent: 07-04-2021 21:47
Subject: Visual Logic node
Basically isOnline distinguishes between being live or preview/not online at all. If it's only visible in preview, isOnline is false. If it's actually online, it's true (obviously).
James Hope
Technical Director
3ABN Australia Inc
Australia
Sent: 07-02-2021 05:59
I was playing around with Visual Logic to try various ways to reset a timer after being used.
While doing so i noticed the node Scene - IsOnline, which gives a boolean as result.
I figured this node could be usefull to reset a timer as soon as the scene goes offline.
But as far as i'm aware, Visual Logic does only run when a scene is online...which makes this node kind of strange...
What does this node do? How can i put it to use?
Thnx!
