  • 1.  how to used Event marker in xpression prime 4.1__
    Posted 05-25-2013 03:58
    how to used Event marker in xpression prime 4.1 .i don't known how to used "script Editor - Event marker events"
  • 2.  RE: how to used Event marker in xpression prime 4.1__
    Posted 05-25-2013 08:37
    Hi Hung
    The Event marker allows you to run scripts, when the scene is shown and when it is hidden. The scripts are based on the XPression SDK. You can find all the available commands in the XPressionSDK.chm help file. Which you can find on your XPression unit at: C:Program Files (x86)XPressionStudioHelp
    The scripting in XPression is extremely powerful and can be used for a variety of things.
    I have for example created automated bar-charts, crawls that removes it background strap with an animation, objects that moves relative to each other etc.
    Best regards
    Niels
  • 3.  RE: how to used Event marker in xpression prime 4.1__
    Posted 05-25-2013 15:19
    Hi Niels Borg
    My divice is xpression prime http://www.rossvideo.com/graphics-system/xpression/editions/prime.html
    not xpression.So i don't know it has support of comman in XpressionSKD.chm help file.If it support i must install what software (like visual basic 2010 epress....)
  • 4.  RE: how to used Event marker in xpression prime 4.1__
    Posted 05-25-2013 15:22
    With prime version, you can't use scripts or API...
  • 5.  RE: how to used Event marker in xpression prime 4.1__
    Posted 05-25-2013 15:34
    Hi Hung
    I hadn't checked if scripting is part of the Prime version.
    Anyway if you at some point decide to purchase a XPression Studio or Studio AE you will be able to radically enhance your output.
    At our facility we have 3 units (2 Studio AEs and 1 Bluebox) and I could not generate the required output without the benefits of the scripts.
  • 6.  RE: how to used Event marker in xpression prime 4.1__
    Posted 05-25-2013 15:41
    Just as a note.
    API is not included as a standard option in all editions of XPression and until recently this was not an available in XPression Prime at all.
    This was recently added as a licensed option for XPression Prime, so it can be added for existing clients (versions permitting).
    Cheers,
    -g
  • 7.  RE: how to used Event marker in xpression prime 4.1__
    Posted 05-25-2013 16:11
    So i must purchase to add API function ?
  • 8.  RE: how to used Event marker in xpression prime 4.1__
    Posted 05-25-2013 16:17
    Hi all
    I have a Qestion that with Prime version i can make this effect :
    i want creat crawl effect with text crawl and has a background bar for text so i creat a scene group with bar in main scene and text in child scene.but when text crawl end the bar not disappear.so i want it automatic disappear when crawl end.so what i need to do.
    Thank.
