  • 1.  Keying a live source
    Posted 11-03-2021 14:57
    We are sending a live feed into Xpression and then to air. Is there any way to key out the background of a live source?
    Thank you,
    Vern
    Vern Horst
    Multimedia graphics producer
    AccuWeather.com
  • 2.  RE: Keying a live source
    Posted 11-03-2021 14:58
    Yes, you will need the CK option on your XPression though.
    Test Pilot | Senior Graphic Programmer & Designer
    London United Kingdom
  • 3.  RE: Keying a live source
    Posted 11-03-2021 15:26
    Simon, thank you. Where do I find the CK option?
    Vern
    Vern Horst
    AccuWeather.com
  • 4.  RE: Keying a live source
    Posted 11-03-2021 15:33
    but it's not a standard feature.
  • 5.  RE: Keying a live source
    Posted 11-03-2021 15:51
    Oh right! Thank you.
    Vern Horst
    AccuWeather.com
  • 6.  RE: Keying a live source
    Posted 11-04-2021 13:26
    Hey Simon,
    I know you said this is not standard, however, is this Chroma Key effect something we should have on Flex as well as Designer? If not how do we get it in Flex?
    Vern Horst
    AccuWeather.com
  • 7.  RE: Keying a live source
    Posted 11-05-2021 05:48
    Hey,
    You must speak to your RSM or local reseller, they can add it to your dongle, you only need to add it to the machines you wish to key on.
    This method will require you to fo add the CK effect to the scene on the live machine each time so to save time you could add to the designer as well so that the offline person could add it into the project and no one else has to worry about it.
