  • 1.  Daktronics Allsport 5000 into Xpressio
    Posted 02-03-2020 06:17
    Hi, current setup has Allsport 5000 serial output > Lantronics Serial to Ethernet > Daktronics Network for scoring data. I would like to take a sniff of the daktronics serial data and present it to XPression via Datalinq. Can anyone help me out with any info regarding this?
  • 2.  RE: Daktronics Allsport 5000 into Xpressio
    Posted 02-04-2020 17:13
    Hi Karl
    We use something called ScoreBot from Sport Cast https://www.scorecasts.net/.  The only major issue we have had is the initial setup which needed in house IT to allow the ip address to talk to our truck. Make sure you have a manual version of your score in case as with every internet based item traffic is always a determining factor.  Also make sure your browser doesn't have 10 active pages as it has messed up things for us with Chrome once.
    Hope this helps.
    Brad
  • 3.  RE: Daktronics Allsport 5000 into Xpressio
    Posted 02-10-2020 20:01
    Do you have any current access to the serial data via an AllSport?  You can just pull the data via something like Teraterm to look at it.
    Steve.
  • 4.  RE: Daktronics Allsport 5000 into Xpressio
    Posted 02-11-2020 03:25
    I would start by setting up a Datalinq source to listen to the Allsport data on whatever UDP port it's being sent on.  Likely port 21000 or 21321 or similar.  Otherwise, I believe you can log into the Lantronics box and add IPs/Ports to send the data to.
