Hi Darcy,
I read you DM, but I prefer to answer in the 'open' channel so other also benefit. I initially missed that you are using a 64-bit version of XPression.
Not sure if this helps, but we're using V15.5.3 of the AJA-driver with the firmware it comes with. However we're still using the 32-bit version.
Kind regards,
Gerard de Vries
Solution Architect Live Graphics & Virtual Graphics
EMG
The Netherlands
Sent: 11-24-2021 10:43
Subject: XPression Studio V10.5 64bit with AJA Corvid 88
Hi Darcy,
The AJA Control Panel will report what firmware is already installed on the board and which firmware is desired for this driver version. If the two don't match, update the firmware. This firmware is included with the driver so always is the right version.
Kind regards,
Gerard de Vries
EMG
The Netherlands
Sent: 11-09-2021 15:28
I've just installed XPression Studio V10.5 64bit on our Corvid 88 system.
I've installed the AJA 12.5.7 drivers. (re: the XPression Video IO Cards & 3rd Party Driver Specs)
Should I be using this latest Corvid 88 firmware with the 12.5.7 drivers?
'Version 0x3f - 4/28/2021 - corvid_88_2021-04-28.bit'
D'Arc
DArcy Pickering
BANNISTER LAKE SOFTWARE
