  • 1.  xPression Text Gradients
    Posted 10-11-2021 19:35
    Curious if anyone can help me with these two questions:
    Is there a way to do a text gradient from left to right that does NOT apply on a by character basis.
    Is there a way to make a Quad an 'alpha mask' of a text object (how its done in AE)
    I have attached a reference image ('COMING UP') as well as an image to show what I am getting from the gradient on a by character basis.
    The other image shows another method I tried where I pulled in a 'Layer Object'. The first child of the Layer Object is a "Text" object. The second child is a 'Quad'.
    For the Quad, I assigned a Material Gradient and turned OFF the 'Rendering: alpha'.
    - As you can see this accomplishes what I wanted but it is very pixelated So it will not work.
    Dalton Paul
    Senior Graphics Producer
  • 2.  RE: xPression Text Gradients
    Posted 10-12-2021 03:16
    Hi Dalton,
    In answer to your question, no, unfortunately you can only apply the materials on a per character basis. Try creating the gradient using Multiply as the material Blending mode, and maintain the same structure within the Layer Object.
    Matt Gamble
  • 3.  RE: xPression Text Gradients
    Posted 10-12-2021 04:47
    Another way is to make the text a mask and have a gradient on a layer underneath the background colour you want and have the text cut through that.
    Test Pilot | Senior Graphic Programmer & Designer
    London United Kingdom
  • 4.  RE: xPression Text Gradients
    Posted 10-12-2021 10:41
    This worked thank you!!!
    Solve:
    I made the Text and Quad Objects a child of the Layer Object. (Text on Top).
    Then Made the Gradient as a Material and set the Blend Mode to Multiply. Then using visual Logic, linked the Text Bounding box to the width of the Quad so the quad only stays the same width as the text object.
    Dalton Paul
  • 5.  RE: xPression Text Gradients
    Best Answer
    Posted 10-12-2021 13:02
      |   view attached
    Dalton,
    There is a function in the Tabs & Options section of the Object Inspector which does provide a method to apply the gradient to Characters or the width of the text object, or the scene dimensions. See if this works for you.
    Patrick Twomey
    Director of Graphics Product Management
    [www.rossvideo.com/XPression]
  • 6.  RE: xPression Text Gradients
    Posted 10-12-2021 18:08
    I knew I was missing something so simple.
    Thank you!
    Dalton Paul
