Hi all,
Rather loaded question, or questions rather today. Those being:
1.) Has anyone found a way to incorporate motion blur into any of their scenes and found a way to animate the blur? With visual logic or not?
2.) Has anyone found a way through the key graph editor, visual logic, or in any other way to create the effect similar to that of After Effect's Easy Ease that can be used and manipulated in After Effect's key graph editor?
3.) Has anyone found a way to not only use cameras to animate in, out, and around scene assets, but to create the blur that cameras can afford such as a Depth of Field blur, I am aware that is an effect in the effects pane, however we need to be able to animate the depth of field in and out. Is this possible in anyway, wether it be with visual logic, texture mapping or not?
