I tried the pdf just now, out of curiosity, without success. Looks like the Sheets v3 API has been turned down. I'm commenting on this thread so that I get notified, in case someone knows how to use Google Sheets in 2022.
Matt Finlayson
Brigham Young University
Sent: 06-15-2022 20:47
Subject: Using Google Sheets for real-time data
Hey Garner, I tried using this pdf guide to get a google sheet to populate in datalinq, but when I go to browse the data, the window is empty - no data. Has anything changed with this since you originally posted in 2021?
Chris Simonson
Sent: 04-12-2021 14:59
I haven't tried this method recently - but it worked last time I tried it in summer 2020. See attached PDF.
Sent: 04-08-2021 12:07
Does Xpression Datalinq support Google Sheets to retrieve real-time data such as changing dollar amounts the someone enters? I have only used RSS feeds and EXcel for data before but I need a different way to get data for a project. I would appreciate anyone's advice on this. Thank you.
Mark Stasiowski
