  • 1.  Xpression: configure input on Matrox?
    Posted 04-13-2022 11:47
    As installed, Matrox DSXLE4/8/100F configured for 4 Fill/Key outputs.  Trying to add an input channel for live mapping.  But in Matrox DSX Framebuffer setup page, when trying to add a Fill input, it adds a line in red "Fill input: exceeds device capacity".
    Also tried deleting all outputs in the I/O Config, rebooted, but the I/O Mode dropdown is greyed out on "8 OUT", no option to change to any sort of input configuration.  Documentation says the board does 2 in / 6 out.
    Thoughts?  Thanks!
    Bob Woodhead
  • 2.  RE: Xpression: configure input on Matrox?
    Posted 04-14-2022 07:17
    Hey Bob- Reconfiguring the Matrox card to be 6in/2out isn't hard, but it involves some command line trickery.
    Drop Tech Support a note and they should be able to give you the instructions you need.
    Bo
    Bo Cordle
    Rocket Surgery
    Charleston, SC
  • 3.  RE: Xpression: configure input on Matrox?
    Posted 04-14-2022 08:11
    Number of in- and outputs are also limited by the version of dongle you have...
    Rob van Rooyen
    Senior Graphics Specialis
    NEP The Netherlands
    Hilversum Netherlands
  • 4.  RE: Xpression: configure input on Matrox?
    Posted 04-14-2022 11:32
    Thanks guys, I'll pass this info along to engineering.
    Bob Woodhead
