I'm trying to use visual logic to change the material applied to a quad based on a text layer.
For example, if the text layer says D, I want the material of a quad to change to a blue material.
If the text layer says R, I want the material of the quad to change to a red material.
If the text layer says G, I want the material of the quad to change to a green material.
Is this possible?
