Xpression PNG question
  • 1.  Xpression PNG question
    Posted 09-08-2021 16:21
    Why won't png import as transparent?  The background around image is still present (the transparent white that is).
    Patrick Orser
    AV specialist
    The Bayview Yards
  • 2.  RE: Xpression PNG question
    Posted 09-09-2021 05:00
    Hi Patrick,
    XPression (obviously) should just import the PNG and use the transparency. We never have had problems doing this. Any chance the designer forgot to save/export the PNG with transparency? Or that the "Ignore Object Alpha" option accidentally got ticked in the Texture settings of the created material? If you can share your XPF (with just 1 scene containing the object and 1 material referencing the PNG), as well as the PNG itself, I can take a look to see what's wrong.
    Kind regards,
    Gerard
    Gerard de Vries
    Solution Architect Live Graphics & Virtual Graphics
    EMG
    The Netherlands
  • 3.  RE: Xpression PNG question
    Posted 09-09-2021 10:27
    Hello...  Ignore Object Alpha was not checked off...  I don't know who originally made graphic as I'm just using a sample I found online.
    Patrick Orser
    AV specialist
    The Bayview Yards
  • 4.  RE: Xpression PNG question
    Posted 09-09-2021 10:28
    Patrick Orser
    AV specialist
    The Bayview Yards
  • 5.  RE: Xpression PNG question
    Site won't let me post the png
    Patrick Orser
    AV specialist
    The Bayview Yards
  • 6.  RE: Xpression PNG question
    Posted 09-09-2021 10:32
    Ok so I used this one:
    Patrick Orser
    AV specialist
    The Bayview Yards
  • 7.  RE: Xpression PNG question
    Posted 09-09-2021 10:33
    Still same issue....
    Patrick Orser
    AV specialist
    The Bayview Yards
  • 8.  RE: Xpression PNG question
    Posted 09-09-2021 10:36
    Hey Patrick,
    Just tried the picture you linked above and it worked for me; which version of XPression you running?? Can you send us the steps your doing to import the asset into XPression?
    Brandon Derry
  • 9.  RE: Xpression PNG question
    Posted 09-09-2021 10:40
    That was a jpeg...  sorry site said png downloads!  Here is a png I will use!
    Patrick Orser
    AV specialist
    The Bayview Yards
  • 10.  RE: Xpression PNG question
    Posted 09-09-2021 10:43
    I'm running version 10.0 (64bit).
    My steps:
    Save image to folder
    Click and drag image from folder onto scene
    Patrick Orser
    AV specialist
    The Bayview Yards
  • 11.  RE: Xpression PNG question
    Hey Patrick,
    Still works for me, which version of XPression are you running?
    Brandon Derry
  • 12.  RE: Xpression PNG question
    Posted 09-09-2021 10:44
    10.0
    Patrick Orser
    AV specialist
    The Bayview Yards
  • 13.  RE: Xpression PNG question
    Posted 09-09-2021 10:47
      |   view attached
    Is this what you are seeing? if so it is because the image on the site itself when right clicking and save to folder contains white; I followed the download buttons for the image. Can you try the attached image?
    Brandon Derry
  • 14.  RE: Xpression PNG question
    Posted 09-09-2021 10:49
      |   view attached
    Attaching ZIP as well..
    Brandon Derry
    Attachment(s)
    zip
    Daco_244389.zip   25 KB 1 version
  • 15.  RE: Xpression PNG question
    Posted 09-09-2021 10:51
    Still white background
    Patrick Orser
    AV specialist
    The Bayview Yards
  • 16.  RE: Xpression PNG question
    Posted 09-09-2021 10:52
    And the first image is what I'm seeing
    Patrick Orser
    AV specialist
    The Bayview Yards
  • 17.  RE: Xpression PNG question
    Posted 09-09-2021 11:41
    this is happening now on a second computer we have...  the third is off site so I can't test it today
    Patrick Orser
    AV specialist
    The Bayview Yards
  • 18.  RE: Xpression PNG question
    Posted 09-13-2021 09:23
    I looked at the PNG files from that site and they are saved as 8bits per pixel.
    Version 10 and below of XPression require 32 bits per pixel (8bit Red, 8bit Green, 8bit blue, 8bit Alpha).  To be honest I've never encountered an 8 bit per pixel PNG before, so these seem pretty rare.
    However, upcoming versions of XPression do have support for this format.
    If you need to use these specific PNG's you would need to resave them as 32bit PNG's.
    Brian Ford
