Video Headshots all in 1 Scene
  • 1.  Video Headshots all in 1 Scene
    Posted 10-08-2019 19:06
    For a goal summary scene I have data keys setup to populate information. The goal scorer will have an animated headshot. The problem I am having is not overloading the performance when taking it to air. I have tried placing all of the headshots in its own scene director, I have also tried placing all of the headshots as a layer in material and use visual logic to enable and disable that layer. I still have the performace issue though.
    Any one have any advice or thoughts how I can make this work in one scene and not have each player in there own scene?
  • 2.  RE: Video Headshots all in 1 Scene
    Posted 10-08-2019 19:12
    Did you convert the videos into the Xpression codec using the video coder on the system?  I would also encourage you that anything that can be still to be still.  So like if it is an animated headshot, but most of the background is static, I would build the background into the scene and then have the video as a different quad.
  • 3.  RE: Video Headshots all in 1 Scene
    Posted 10-08-2019 19:14
    Can you give us more information about headshots number, video resolution and file size?
  • 4.  RE: Video Headshots all in 1 Scene
    Posted 10-08-2019 19:46
    The number of headshots is 26 total. Video Resolution is 1920x1080 and has been converted to the Xpression AVI codec as I do with any video I receive. I have attached the project package.
    https://pmieg-my.sharepoint.com/:u:/g/personal/jeff_bins_pmiwi_com/EVtu-_zPbIBNkuyXnbJpJJkBTQXUlKzcOlbUan0dVgHKNQ?e=gFBEjs
  • 5.  RE: Video Headshots all in 1 Scene
    Posted 10-08-2019 19:56
    @garretthall That is how it is all built out. The background is its own layer which is a video material. Then the headshots are on it own quad.
  • 6.  RE: Video Headshots all in 1 Scene
    Posted 10-08-2019 19:59
    @Jeff.  I will try to download this project tonight and look at it.  Just something that came to mind that affected us at Boston College last year.  We were a 1080 house but running a 720 project, so it put extra stress on the machine to up convert inside of the software.  So are you a 1080 house and then need 1080 videos?  Or are you a 720 house and could down convert the videos a little?
  • 7.  RE: Video Headshots all in 1 Scene
    Posted 10-08-2019 20:10
    @Garrett 1080i house. Same as the project.
  • 8.  RE: Video Headshots all in 1 Scene
    Posted 10-09-2019 06:17
    Hey Jeff!
    Hope you don't mind, I've been toying around with doing some Xpression tutorials, so I figured I'd respond to you in Video format!
    https://youtu.be/eZjvzvOiKpE
    Here's the script in the code block:
    dim Headshot as xpQuadObject
    dim Material as xpMaterial
    Scene.GetObjectByName("Headshot", Headshot)
    Headshot.GetMaterial(0, Material)
    Material.SetPlayMode(PlayMode.pm_Once)
    Material.Play()
    Let me know if that's not how it's supposed to look or if I should define something differently!
  • 9.  RE: Video Headshots all in 1 Scene
    Posted 10-09-2019 13:40
    @Zachary Definitely what I am looking for. What type of datalinq source is that, ADODB? I have tried this and when I put in the SELECT function on the table it does not work.
  • 10.  RE: Video Headshots all in 1 Scene
    Posted 10-09-2019 13:41
    @Zachary Note I am running 8.5 (4611)
  • 11.  RE: Video Headshots all in 1 Scene
    Posted 10-09-2019 13:45
    @Zachary NVM. I forgot to label my table. All good now.
  • 12.  RE: Video Headshots all in 1 Scene
    Posted 10-09-2019 16:15
    Glad it worked!
    Just to recap, ADODB datalinq source with Excel (I used XLSX, though it's harder to work concurrently on a sheet with that source).
    To name a table, select all the values you need (including headers), go to the Formulas tab, and hit "Define Name" (or Name Manager)
