  • 1.  Script to Trigger Take ID from a different Xpression
    Posted 06-15-2021 12:39
    I am looking for guidance on if there is a way to trigger a Take ID from a different Xpression using scripting. For instance, If I want my Tessera Xpression (Ribbons) to Display a specific scene when I trigger a full screen on another xpression.
    Has anyone had success doing this. Im assuming its using the Ross Talk Trigger but I am not sure how to direct it to the other xpression.
    Any help is appreciated. Thanks
    Casey Woodman
    Northwestern University Athletics
  • 2.  RE: Script to Trigger Take ID from a different Xpression
    Posted 06-15-2021 12:52
    Hey
    You can place a RossTalk command on the Scene Director and send out commands over Smart GPI.
    Don't forget you'll need to setup your outward GPI and inward GPI in XPression Hardware Setup.
  • 3.  RE: Script to Trigger Take ID from a different Xpression
    Posted 06-15-2021 15:36
    Can this also be accomplished with a script? I am hoping to be able to use a dynamic text field that I can put the Take ID for the Other Xpression if I can.
    Casey Woodman
  • 4.  RE: Script to Trigger Take ID from a different Xpression
    Posted 06-15-2021 16:35
    Yes it can be scripted.
    dim rosstalk as xpGPIBoard
    Engine.GetGPIBoard(0, rosstalk)
    rosstalk.SendMessage("GPI 1")
    'The "0" in the GetGPIBoard is the index of the GPI board in Hardware Setup > GPI Boards
    '(Board #1 = Index 0, Board #2 = Index 1, etc..)
