Thanks, Brian! After some quick tests, I think I'll be able to get this to work.
For anyone else trying to do this, I will summarize:
The key to making this work is to make sure that you:
1) Have a folder that contains your CSV file, and2)
The datalinq must be configured as so:Provider=Microsoft.Jet.OLEDB.4.0;Data Source=P:\Election_Results\ResultsXpression\csv;
Extended Properties="text;HDR=Yes;FMT=Delimited";
Make sure to point Data Source to the folder containing your file.
3) The table name will be the file name, so If the file is named CandidateInfo.csv then the table name will be [CandidateInfo#csv] in Xpression.
4) The queries will be in the following format:
SELECT * FROM [CandidateInfo#csv] ORDER BY Votes DESC
where the table is the file name followed by a hashtag and csv, and Votes from my example is the name of the column (defined in the header row of your .csv) that you want to sort by.
In my example I was able to presort the data in the datalinq configuration. By the time I looked at it in Xpression, row 1 was always the person with the most votes, and row 2 had the second-most votes, etc. in descending order.
Nathan S.
Sent: 08-30-2021 12:58
Subject: SQL Query Sort using csv (no/unamed table?)
The microsoft ADODB JET driver should be able to read .CSV files also, which would allow sorting.
Try putting the CSV file into a folder and setting it in the connection string like this (d:\CSV in my example):
Provider=Microsoft.Jet.OLEDB.4.0;Data Source=d:\csv;Extended Properties="text;HDR=Yes;FMT=Delimited";
You should be able to then use SQL to sort the table.
Brian Ford
Sent: 07-14-2021 15:42
Digging around on the forums, it seems that SQL queries only work with ADODB sources. Is this correct?
On that track, I opened the csv file in excel and exported it as an .xlsx file, which I used with an ADODB datalinq. This was fine, but I had no table to select in expression so I resorted to creating a dummy worksheet in my excel file. This allowed me to see and select a table, and sorting did work.
This can't be a solution for me though, as I can't automate creating an excel file from a CSV. I can't be the first person to want to sort a csv in expression. What is the proper solution here? Again, please help.
Nathan S.
Sent: 07-14-2021 10:11
Using SQL Queries to Automatically Order External Data Dynamically | Ross Video
Hi, I found the preceding video and was hoping to use it as a guide to pre sort some data for graphics. My datalinq is looking at a .txt formatted CSV file with a header row. I hope this is something simple, but I don't have a table name so I can't seem to get an SQL query to work following the tutorial as a guide.
Any help would be great appreciated, thanks!
Nathan S.
