You can either script it. The number 540 is a variable number. Change this to change the location on the screen.
Dim text as xpTextObject
dim height as integer
Self.GetObjectByName("Text1", text)
height = text.boundingbox.height
text.posY = height / 2 + 540
Or use visual logic to reposition the text. Again the number 540 will change depending where you want to position it on the screen.
Make sense?
Lesley Mitchell
Special Projects
Bell Media
Toronto, ON Canada
Sent: 05-02-2021 02:32
Subject: How To Text alignment Horizontally Center when typed?
Bibek Shrestha
Designer
