  • 1.  Blackstorm timecode client embed within custom panel
    Posted 06-03-2015 23:58
    Is it possible to place the blackstorm timecode client within a custom panel, exactly as it would normally look within the blackstorm interface?
  • 2.  RE: Blackstorm timecode client embed within custom panel
    Posted 06-04-2015 13:39
    Hi Trent.
    Unfortunately, there is no integration between CustomPanels and the BlackStorm clients.
    Here's about as close as you can get:
    You can drag tabs to split the screen and show a timecode client at the same time as your CustomPanel.
    You can also use DashBoard's VDCP control scripting to list clips, pause, cue, play, and find out the ID of the active clip on each channel.
    Sorry I don't have a better answer for you.
    James
