Hi Tamer,
Sorry for the delayed response. I think the shortcut assignment is not limited to Tab and Shift + Tab, You can set the shortcut to any key you wish by double-clicking on the shortcut column and typing the key. Please feel free to reach out if you were looking to do something else.
Best Regards,
Altaz Daruwala
Sent: 02-26-2024 04:22
Subject: Keyboard Shortcuts to Buttons
Hello Brando,
i follow this and its work but i have to assign only Tab and Shift+Tab and i have many buttons any more way to assign more ?
TAMER ABDELAZIZ
ONTV
CAIRO Egypt
Sent: 01-12-2017 20:16
This is pretty easy to do. In Dashboard, Edit your button and there is a Trigger ID. Give this a number. Then go to Window > Preferences > Keyboard shortcuts. Click new Command, Click fire GPI, set your short cut and when you want this to be active, then put in the GPI number (your trigger ID) and it should work.
