Hi Jurgen.
There is currently no command in the DashBoard VDCP library to get the current clip's position.
There are mechanisms to get the clip's duration and the active clip's ID - just not the current position. This makes showing a timer for a clip already in progress very difficult.
The only way to show a timer counting down the time remaining in a DashBoard Custom Panel is if the clip is also cued from that custom panel (that way a timer can be started at the same time as the clip).
Is this something you're planning on doing?
James
