There are two different methods you could be talking about here.
1: Creating a clock widget in XPression and controlling it from DashBoard.
2: Creating a clock widget in DashBoard, and, streaming its data over to Xpression.
astalsberg is referring to Method 2.
If you happen to be looking at method 1 you will have to:
-Send GPI messages from DashBoard to XPression.
-In XPressoin, create macros that implement the features you want.
-In Xpression map receiving that GPI into the macro.
From an earlier Post by James on how to do this:
"The easiest way would be to go into XPression's Keyboard/GPI Mapping and, at the same action you would use to assign a keyboard shortcut, also edit the GPI assignment to add a RossTalk/SmartGPI number. You would also add a RossTalk/SmartGPI port under Hardware Setup -> GPI Boards.
You can then use the "GPI" command in Visual Logic to send the GPI number you assigned to the XPression."
Troy.
