  • 1.  Panel link path
    Posted 12-13-2017 15:44
    I have come up with a little problem. I moved my DashBoard to another path and found all my panel links were gone. Is there a way to have the links set for a relative path rather than an absolute path? All my panels are in a folder called Panels with sub folders it would be great if the panel link would just use the Panel folder and its sub folder as its path..
  • 2.  RE: Panel link path
    Posted 12-13-2017 17:00
    When you created the panel links originally, did you use the "File Navigator" or the "Local File" option?
    If you use "Local File" and the panels are all in the same folder (or a sub-folder) of your panel, then it will use a relative path by default. The "file navigator" will use a more absolute path.
    James
