  • 1.  computers ip address?
    Posted 09-23-2018 05:55
    im trying to figure out what i set my computers IP address to so I can access my OGX thru dashboard. I already now the OGX IP address 192.168.2.1, but not the computers. any help would be very helpful. thank you
  • 2.  RE: computers ip address?
    Posted 09-24-2018 12:08
    Not sure what you're trying to do here.. Are you just after a way to get your PC/MACs IP?
    Or are you trying to get the IP adress of your machine through DashBoard script?
  • 3.  RE: computers ip address?
    Posted 09-24-2018 14:31
    If you are on a Windows machine, you can open a command prompt (start->"CMD"->Enter) and type "ipconfig /all" to see all of the IP address information for all of your Ethernet adapters.
    If you are on Linux, you would use a terminal window and type "ifconfig" to view similar information.
    You can find a fairly-comprehensive guide to getting/setting IP addresses on many versions of Windows here:
    https://www.howtogeek.com/howto/19249/how-to-assign-a-static-ip-address-in-xp-vista-or-windows-7/
    Cheers.
    James
  • 4.  RE: computers ip address?
    Posted 09-30-2018 03:43
    Got it thanks for your input
