  • 1.  Make table read only
    Posted 12-02-2016 01:18
    Is there a way to make a table read only?
    When you click on a cell it lets you edit the contents. My table is populated from an XML file, so I'd rather not allow that.
  • 2.  RE: Make table read only
    Posted 12-02-2016 14:58
    Easiest way? Make the default widget for the parameter(s) you're showing in the table a "label".
    You can do this in the param editor dialog.
  • 3.  RE: Make table read only
    Posted 12-02-2016 19:13
    Seems to do exactly what I needed, thanks.
