Sorry for late respon ...
We have an event wich need to 2 CG operator.
operator 1 is responsible to operate & Design template & Name Timer, Credit and another graphic.
operator 2 is responsible to "operate" subtitle Al-quran ayat only (operator not familiar with Xpression)
My plan is use 1 X-pression machine with 2 Controler. One on Xpression it self, onether one is in Laptop with dasboard interface. We play the xpression base on ID & Layer.
I have sucsessed to control Xpression on local host.
but when I try it on another PC it was failed.
(i have changed the HOST to IP adress)
is there another setting to fix it?
Thanx
