  • 1.  Global functions
    Posted 02-18-2016 15:16
    I'm trying to make a global function that will return a value. I'm using a Lookup called 'Functions' with the ogScript for the function in the lookup Value, and the name of the function as the Key. I'm calling it with :
    %const['Functions']['myGlobal']% myGlobal("test");
    This works well until I try to add a return value to the function when I get an error. Is this the best way to implement a global function, and are return values possible?
    Many thanks,
    Martin
  • 2.  RE: Global functions
    Posted 02-27-2016 15:40
    I think I've found the answer - put any global functions inside an tag. They are then globally visible, and can have a return value.
