How about getting clip remaining time from
#XPression?
Single clip or group (back to back set of clips)?
Hoping that there may have been some methods figured out in the 3 years since this post!
Michelle Owczarski
Sent: 02-22-2018 20:32
Subject: Clip Time Remaining
Hi @styresd
Graphite does not currently expose this information in a way that DashBoard can access. Sorry!
There are ways of creating timers that you could start at the same time as you play a clip (provided you are also using DashBoard to play the clip) but it would involve manually-setting the timer duration and starting it.
James
