Is there anyway in DashBoard to set a timeout on a function? I have a function in my api that is doing a ogscript.post command and getting info back from a AJA Ki Pro Device. The problem I have is if the network is not connected or the IP address is incorrect, the dashboard will hang for a good 30 seconds and become unresponsive. is there anyway to force the function to timeout after a certain amount of time?
