Is you device a DashBoard Connect device or an openGear device? That is, does it live in an openGear Frame and use the CAN Bus to communicate?
If it is openGear, the only way around the limit is to use external objects (note: these can be used for parameter
constraints, not parameter
values).
If it is DashBoard Connect, set the overall value length byte (the one that would normally provide the length of all elements of the array combined) to 0.
