  • 1.  Dashboard Locking up immediately on OSX
    Posted 04-18-2014 01:03
    Hi!
    As soon as I open any recent version of Dashboard on a certain Mac running OSX 10.7.5 it tries to open a previous tab layout, and then immediately becomes unresponsive. This includes the latest version: 6.1.
    I have uninstalled the application as best I know how: by deleting the Dashboard folder from Applications, emptying the trash, then restarting the computer.
    However, any fresh install, including new versions or Beta versions exhibit the same problem; they come back with the same tabs layout and immediately lock up.
    Are there any preferences saved elsewhere that I can delete to make this work again? Any other thoughts, besides wiping the computer and starting over?
    Thanks,
    David
  • 2.  RE: Dashboard Locking up immediately on OSX
    Posted 04-18-2014 18:12
    Hi David.
    Sorry you are having so much trouble getting the application to launch.
    There is likely something happening in the restore process where DashBoard restores its previous state on launch. While I would like to investigate further, let's get you back up and running first.
    DashBoard on Mac OS X stores its configuration date in /Library/Application Support/openGear/DashBoard/.metadata
    This is where the problematic file lives (and why you aren't having any luck by just removing the /Applications/DashBoard folder).
    If you don't have much in the way of customized settings and want to start with a clean slate, I recommend executing the following in a command prompt:
    cd /Library/Application Support/openGear/DashBoard
    mv .metadata .metadata.broken
    If you do have a lot of customized settings you don't want to lose, you can also simply remove the DashBoard restore file:
    cd /Library/Application Support/openGear/DashBoard/.metadata/.plugins/org.eclipse.ui.workbench/
    rm workbench.xml
    After that, you should be able to launch DashBoard.
  • 3.  RE: Dashboard Locking up immediately on OSX
    Posted 04-19-2014 00:52
    Thanks James!
    I had no customizations made so I used the first option and it worked perfectly!
    Thanks again,
    David
