Hyperdeck Control in CCs
Kris Dunlop
Kris Dunlop01-25-2017 19:21
Kris Dunlop
Kris Dunlop01-25-2017 22:04
Kris Dunlop
Kris Dunlop01-25-2017 22:07
Kris Dunlop
Kris Dunlop01-25-2017 22:09
  • 1.  Hyperdeck Control in CCs
    Posted 01-25-2017 02:55
    We have a Ross Carbonite and have dashboard installed. We opened up the document panel build application to control our Blackmagic Hyperdeck. Works great.
    Is there a way to use a custom control to send the record command, so we can hit an actual button on the carbonite?
    Since I didn't setup this default application, I'm not sure how they are talking to the decks.
  • 2.  RE: Hyperdeck Control in CCs
    Posted 01-25-2017 15:07
    Do you mean you
    want the Carbonite to be able to trigger the DashBoard script you're using to control the Hyperdeck?
    If so, turn on the Global RossTalk GPI Listener in Window->Preferences:
    Then, attach a "Trigger ID" to
    You can then trigger through Carbonite by setting up a new RossTalk device and sending the command "GPI 1" to DashBoard's IP address.
  • 3.  RE: Hyperdeck Control in CCs
    Posted 01-25-2017 19:15
    I did all that. Now the document was already created, so here is what I did.
  • 4.  RE: Hyperdeck Control in CCs
    Posted 01-25-2017 19:21
    Custom Control
  • 5.  RE: Hyperdeck Control in CCs
    Posted 01-25-2017 20:34
    After taking a look at the panel you're using, you'll have to break things up a little bit more.
    Easiest approach I can see is if you take the record button and break it up into 2 pieces: RECORD START and RECORD STOP... Give these 2 different trigger IDs (perhaps 4 and 5).
    You can then trigger the start and stop independently from the custom control
    Also worth noting that you've assigned a trigger ID of "4" to your button but are triggering ID "1" from your custom.
  • 6.  RE: Hyperdeck Control in CCs
    Posted 01-25-2017 20:52
    On 4 and 1, I was trying everything I could. I'm not sure what to do I guess. The button is toggle record command. So it starts on one and stops on second push. Not sure if I can split it up. It is the application that is on your website as an example. Sorry.
  • 7.  RE: Hyperdeck Control in CCs
    Posted 01-25-2017 20:56
    Trying options and didn't change back before screenshot, regarding 4/1
  • 8.  RE: Hyperdeck Control in CCs
    Posted 01-25-2017 21:08
    Here is a version with 2 buttons:
    <abs contexttype="opengear" id="topLevel" sharedsession="true" style="bg-u:;bg#dark;" virtualheight="947" virtualwidth="1606">
       <meta>
          <params>
             <param access="1" constrainttype="INT_CHOICE" name="Clip List" oid="0x2" precision="0" type="INT32" value="0" widget="7">
                <constraint key="0">no clips loaded</constraint>
             </param>
             <param access="1" maxlength="0" name="RecordClipName" oid="0x3" type="STRING" value="LesNewPanel" widget="3"/>
             <param access="1" constrainttype="INT_CHOICE" name="RW Speed" oid="0x4" precision="0" strvalue="-200" type="INT32" value="1" widget="7">
                <constraint key="0">0</constraint>
                <constraint key="1">-200</constraint>
                <constraint key="2">-800</constraint>
                <constraint key="3">-1600</constraint>
             </param>
             <param access="1" constrainttype="INT_CHOICE" name="FF Speed" oid="0x5" precision="0" strvalue="0" type="INT32" value="0" widget="7">
                <constraint key="1">200</constraint>
                <constraint key="2">800</constraint>
                <constraint key="3">1600</constraint>
             </param>
             <param access="1" constrainttype="INT_CHOICE" name="RecVidInput" oid="0x6" precision="0" strvalue="SDI" type="INT32" value="0" widget="7">
                <constraint key="0">SDI</constraint>
                <constraint key="1">HDMI</constraint>
                <constraint key="2">component</constraint>
             </param>
             <param access="1" constrainttype="INT_CHOICE" name="RecAudInput" oid="0x7" precision="0" strvalue="XLR" type="INT32" value="1" widget="7">
                <constraint key="0">embedded</constraint>
                <constraint key="1">XLR</constraint>
                <constraint key="2">RCA</constraint>
             </param>
             <param access="1" constrainttype="INT_CHOICE" name="RecButton" oid="0x8" precision="0" strvalue="Record Clip" type="INT32" value="0" widget="13">
                <constraint key="0">Record Clip</constraint>
                <constraint key="1">RECORDING</constraint>
             </param>
             <param access="1" maxlength="0" name="IP Address" oid="0x9" type="STRING" value="10.62.141.18" widget="3"/>
          </params>
          <lookup id="hosts">
             <entry key="BlackmagicDeck1.host"/>
             <entry key="BlackmagicDeck1.port">9993</entry>
          </lookup>
          <style id="ToggleButtons" name="ToggleButtons" value="fg#selectfg;txt-align:center;size:Bigger;bg#panelbg;t:fg#selectfg;t:bg#selectbg;t:size:Bigger;t:txt-align:center;f:bg#panelbg;f:fg#selectfg;f:txt-align:center;f:size:Bigger;"/>
          <style id="Transport" name="Transport" value="bdr#control;bg#selectfg;size:Bigger;fg#readonlyfg;txt-align:center;font:default;t:bdr#control;t:bg#selectfg;t:bg-align:center;t:font:default;t:size:Bigger;t:fg#listfg;t:txt-align:center;f:bdr#control;f:bg#control;f:font:default;f:size:Bigger;f:fg#listfg;"/>
          <ogscript handles="onload" id="" name="onload">var choices = new Array();
    choices.push('Press Load Clips to Initialize');
    var choiceConstraint = params.createIntChoiceConstraint(choices);
    params.replaceConstraint(0x2, choiceConstraint);
    ogscript.putPrivateString('hosts', 'BlackmagicDeck1.host', params.getValue(0x9,0));
    //params.setValue(0x9, 0, ogscript.getPrivateString('hosts', 'BlackmagicDeck1.host'));
    ogscript.debug('onload complete: ' + params.getValue(0x9, 0));</ogscript>
       </meta>
       <tab height="817" id="theBiz" left="24" tabposition="north" top="114" width="1561">
          <abs name="Production" virtualheight="777" virtualwidth="1547">
             <table height="532" right="2" style="bg#dark;bdr:etched;" top="77" width="757">
                <tr>
                   <label colspan="3" fill="both" height="60" name="Record" pheight="60" pwidth="744" style="txt-align:center;font:bold;size:Bigger;" weightx="0" weighty="0"/>
                </tr>
                <tr>
                   <label colspan="1" fill="both" left="512" name="Record Clip Name" pheight="108" pwidth="376" rowspan="1" style="txt-align:west" top="25" weightx="1.0" weighty="1.0"/>
                   <label colspan="1" fill="both" left="849" name="Video Source" pheight="108" pwidth="368" rowspan="1" style="txt-align:west;" top="20" weightx="1.0" weighty="1.0"/>
                </tr>
                <tr>
                   <param colspan="1" fill="both" left="507" oid="0x3" pheight="114" pwidth="376" rowspan="1" top="66" weightx="1.0" weighty="1.0"/>
                   <param colspan="1" fill="both" left="849" oid="0x6" pheight="114" pwidth="368" rowspan="1" top="65" weightx="1.0" weighty="1.0">
                      <task tasktype="ogscript">var Input = params.getStrValue(0x6, 0);
    ogscript.debug('configuration: video input: ' + Input);
    rosstalk.sendMessage(ogscript.getPrivateString('hosts', 'BlackmagicDeck1.host'), parseInt(ogscript.getPrivateString('hosts', 'BlackmagicDeck1.port')), 'configuration: video input: ' + Input);</task>
                   </param>
                </tr>
                <tr>
                   <dropspot colspan="1" fill="both" pheight="108" pwidth="376" rowspan="1" weightx="1.0" weighty="1.0"/>
                   <label colspan="1" fill="both" left="848" name="Audio Source" pheight="108" pwidth="368" rowspan="1" style="txt-align:west;" top="104" weightx="1.0" weighty="1.0"/>
                </tr>
                <tr>
                   <simplegrid colspan="1" fill="both" pheight="130" pwidth="376" rows="1" rowspan="1" weightx="1.0" weighty="1.0">
                      <button buttontype="push" gpi="3" name="RECORD START" style="bdr#000000;o#000000;size:Bigger;font:bold;bdr:etched;">
                         <task tasktype="ogscript">var RecClipName = params.getStrValue(0x3, 0).trim();
    ogscript.debug(RecClipName);
    if (RecClipName != null)
       rosstalk.sendMessage(ogscript.getPrivateString('hosts', 'BlackmagicDeck1.host'), parseInt(ogscript.getPrivateString('hosts', 'BlackmagicDeck1.port')), ' record: name: ' + RecClipName + ' ');
    else
       rosstalk.sendMessage(ogscript.getPrivateString('hosts', 'BlackmagicDeck1.host'), parseInt(ogscript.getPrivateString('hosts', 'BlackmagicDeck1.port')), ' record');
    }</task>
                      </button>
                      <button buttontype="push" gpi="4" name="RECORD STOP" style="bdr#000000;o#000000;size:Bigger;font:bold;bdr:etched;">
                         <task tasktype="ogscript">rosstalk.sendMessage(ogscript.getPrivateString('hosts', 'BlackmagicDeck1.host'), parseInt(ogscript.getPrivateString('hosts', 'BlackmagicDeck1.port')), ' stop');</task>
                      </button>
                   </simplegrid>
                   <param colspan="1" expand="true" fill="both" left="849" oid="0x7" pheight="130" pwidth="368" rowspan="1" top="140" weightx="1.0" weighty="1.0">
                   </param>
                </tr>
             </table>
             <table height="537" left="75" style="bdr:etched;bg#dark;" top="77" width="630">
                <tr>
                   <label colspan="3" fill="both" height="60" name="Playback" pheight="60" pwidth="616" style="txt-align:center;font:bold;size:Bigger;" weightx="0" weighty="0"/>
                </tr>
                <tr>
                   <button buttontype="push" colspan="1" fill="both" insets="2,2,2,2" left="47" name="&lt;html&gt;&amp;#x25b6;&lt;/html&gt;" pheight="131" pwidth="209" rowspan="1" style="style:Transport;size:Biggest;" top="38" weightx="1.0" weighty="1.0">
                      <task tasktype="rosstalk">rosstalk.sendMessage(params.getValue(0x9, 0), parseInt(ogscript.getPrivateString('hosts', 'BlackmagicDeck1.port')), '   play: single clip: true');</task>
                      <task tasktype="ogparamset">params.setValue(0x5, 0, 0);</task>
                      <task tasktype="ogparamset">params.setValue(0x4, 0, 0);</task>
                   </button>
                   <button buttontype="push" colspan="1" fill="both" insets="2,2,2,2" left="243" name="&lt;html&gt;&amp;#x25a0;&lt;/html&gt;" pheight="131" pwidth="209" rowspan="1" style="style:Transport;" top="38" weightx="1.0" weighty="1.0">
                      <task tasktype="rosstalk">rosstalk.sendMessage(params.getValue(0x9, 0), parseInt(ogscript.getPrivateString('hosts', 'BlackmagicDeck1.port')), ' stop');</task>
                   </button>
                   <dropspot colspan="1" fill="both" insets="2,2,2,2" pheight="131" pwidth="186" rowspan="1" weightx="1.0" weighty="1.0"/>
                </tr>
                <tr>
                   <button buttontype="push" colspan="1" fill="both" insets="2,2,2,2" left="47" name="&lt;html&gt;&amp;#x25c0;&amp;#x25c0;&lt;/html&gt;" pheight="98" pwidth="209" rowspan="1" style="style:Transport;" top="151" weightx="1.0" weighty="1.0">
                      <task tasktype="ogparamset">params.setValueRelative(0x4, 0, 1);</task>
                      <task tasktype="ogscript">var RWSpeed = params.getStrValue(0x4, 0);
    ogscript.debug('play: speed: ' + RWSpeed);
    rosstalk.sendMessage(params.getValue(0x9, 0), parseInt(ogscript.getPrivateString('hosts', 'BlackmagicDeck1.port')), ' play: speed:' + RWSpeed);</task>
                   </button>
                   <button buttontype="push" colspan="1" fill="both" insets="2,2,2,2" left="243" name="&lt;html&gt;&amp;#x25b6;&amp;#x25b6;&lt;/html&gt;" pheight="98" pwidth="209" rowspan="1" style="style:Transport;" top="151" weightx="1.0" weighty="1.0">
                      <task tasktype="ogparamset">params.setValueRelative(0x5, 0, 1);</task>
                      <task tasktype="ogscript">var FFSpeed = params.getStrValue(0x5, 0);
    ogscript.debug('play: speed: ' + FFSpeed);
    rosstalk.sendMessage(params.getValue(0x9, 0), parseInt(ogscript.getPrivateString('hosts', 'BlackmagicDeck1.port')), ' play: speed:' + FFSpeed);</task>
                   </button>
                   <dropspot colspan="1" fill="both" insets="2,2,2,2" pheight="98" pwidth="186" rowspan="1" weightx="1.0" weighty="1.0"/>
                </tr>
                <tr>
                   <param colspan="2" fill="both" id="" insets="2,2,2,2" left="47" oid="0x2" pheight="109" pwidth="422" rowspan="1" top="217" weightx="1.0" weighty="1.0" width="350"/>
                   <button buttontype="push" colspan="1" fill="both" insets="2,2,2,2" left="428" name="Cue Clip" pheight="109" pwidth="186" rowspan="1" style="size:Big;bg#001E98;" top="217" weightx="1.0" weighty="1.0" width="150">
                      <task tasktype="ogscript">var CueClip = params.getValue(0x2, 0);
    ogscript.debug(CueClip);
    rosstalk.sendMessage(params.getValue(0x9, 0), parseInt(ogscript.getPrivateString('hosts', 'BlackmagicDeck1.port')), ' goto: clip id: ' + CueClip);</task>
                   </button>
                </tr>
                <tr>
                   <button buttontype="push" colspan="3" fill="both" insets="2,2,2,2" left="47" name="Refresh Clip List" pheight="109" pwidth="612" rowspan="1" style="o#000000;size:Big;bg#D3CF00;" top="271" weightx="1.0" weighty="1.0">
                      <task tasktype="ogscript">//This is our callback
    //We will pass it to the listener and the listener will notify it when
    //it has received the complete response to the command we sent
    var callbackFunction = function(result) {
       //Reset our 'busy' state
       ogscript.putObject('busy', false);
       //Stop the command sender
       ogscript.getListenerById('commandSender').stop();
       //ogscript.getAllById('commandSender')[0].stop();
       //If we didn't get a result, we can't do much more
       if (result == null || result == undefined) {
          ogscript.debug('no result');
          return;
       else
          ogscript.debug('WE GOT SOMETHING!' + result[0]);
       //If we did, let's update our clip list
       params.replaceConstraint(0x2, params.createIntChoiceConstraint(result));
    //If we are already processing something, we can't process something ELSE
    if (ogscript.getObject('busy')) {
       ogscript.debug('can\'t do anything. already busy');
    } else {
       //Put the connection into a known state
       //Mark oursevles as 'busy' so nothing else gets sent
       ogscript.putObject('busy', true);
       //Store this so the listener knows what to send
       ogscript.putObject('sendCommand', 'clips get');
       //Add a callback for the listener to call when we are done
       ogscript.putObject('callback', callbackFunction);
       //start the listener so it can send the command and read the result
       ogscript.getListenerById('commandSender').start();
       //ogscript.getAllById('commandSender')[0].start();
    }</task>
                   </button>
                </tr>
             </table>
          <abs name="Set Up" virtualheight="777" virtualwidth="1547">
             <table height="193" id="commsTable" left="124" top="131" width="1197">
                <tr>
                   <label colspan="3" eight="24" fill="both" header="true" height="25" name="Enter deck's IP address, then press &quot;Set&quot;" pheight="25" pwidth="1197" style="txt-align:center;size:Big;" width="800"/>
                </tr>
                <tr>
                   <param colspan="1" fill="both" height="100" left="0" oid="0x9" pheight="168" pwidth="897" rowspan="1" style="size:Biggest;" top="0" weightx="1.0" weighty="1.0" width="500"/>
                   <button buttontype="push" colspan="1" fill="both" height="100" name="Set" pheight="168" pwidth="150" rowspan="1" style="size:Bigger;" weighty="0.75" width="150">
                      <task tasktype="ogscript">ogscript.putPrivateString('hosts', 'BlackmagicDeck1.host', params.getValue(0x9,0));
    ogscript.debug('Set IP address to: ' +  ogscript.getPrivateString('hosts', 'BlackmagicDeck1.host'));
    choices.push('no clips loaded');
    params.setValue(0x2, 0, 0);
    ogscript.reload('commsTable');</task>
                   </button>
                   <listener autostart="false" buttontype="toggle" colspan="1" connecthost="%value[0x9][0]%" connectport="%const['hosts']['BlackmagicDeck1.port']%" delimitertype="newline" fill="both" height="100" id="commandSender" left="0" name="Comms" pheight="168" pwidth="150" style="style:ToggleButtons;" top="0" width="150">
                      <task tasktype="ogscript">if (event.isConnectEvent()) {
       ogscript.rename('ConnectLabel', 'Connected&lt;fg#00FF00&gt;');
       var commandToSend = ogscript.getObject('sendCommand');
       ogscript.putObject('sendCommand', null);
       if (commandToSend != null) {
          ogscript.debug('sending command: ' + commandToSend);
          this.writeString(commandToSend + '\n', false);
       } else {
          ogscript.debug ('command to send was null');
    } else if (event.isMessageEvent()) {
       var message = event.getBytesAsString().trim();
       var startmsgsearch = message.indexOf('clip count: ');
       if (startmsgsearch != -1) {
          var clipsnum = message.substr(12, message.length-1);
          ogscript.putObject('ClipsNum', clipsnum);
          ogscript.putObject('ClipsCount', 0);
          ogscript.debug('Number of Clips = ' + clipsnum);
          ogscript.putObject('responseBuilder', new Array());
       } else {
          var clipsnum = ogscript.getObject('ClipsNum');
          var clipscount = ogscript.getObject('ClipsCount');
          if (clipsnum != null) {
             if (clipsnum == clipscount) {
                ogscript.debug('end of response');
                var responseObject = ogscript.getObject('responseBuilder');
                var callback = ogscript.getObject('callback');
                if (callback != null) {
                   ogscript.debug('making callback with ' + responseObject);
                   callback(responseObject);
                ogscript.putObject('ClipsNum', null);
                ogscript.putObject('ClipsCount', null);
             } else if (clipsnum != clipscount) {
                var clipnamestart = message.indexOf(':');
                var clipnameend = message.indexOf('.mov');
                var clipnameparsed = message.substr(clipnamestart + 2, clipnameend - clipnamestart - 2);
                ogscript.debug('clip received: ' + clipnameparsed + ' ' + clipnamestart + ' ' + clipnameend + ' ' + clipnameparsed.length);
                ogscript.debug('clip received: ' + message);
                ogscript.getObject('responseBuilder').push(clipnameparsed);
                clipscount++;
                ogscript.putObject('ClipsCount', clipscount);
              } else {
                ogscript.debug('message received ' + message);
    } else if (event.isDisconnectEvent()) {
       ogscript.rename('ConnectLabel', 'Disconnected&lt;fg#FF0000&gt;');
       ogscript.debug('connection closed');
    } else {
       ogscript.debug('no event info');
    }</task>
                   </listener>
                </tr>
             </table>
             <label height="75" id="ConnectLabel" left="1285" name="Disconnected" style="font:bold;bdr:etched;bg#dark;size:Big;fg#F60505;txt-align:center;" top="7" width="256"/>
       </tab>
       <abs height="75" right="18" style="bg-u:platform:/plugin/com.rossvideo.common.oglml/patterns/ross-150.png;bg-align:center;bg-fill:shrink;" top="11" virtualheight="75" virtualwidth="209" width="209"/>
       <label height="83" left="24" name="Blackmagic HyperDeck Control" right="240" style="txt-align:center;size:Big;font:bold;bdr:etched;bg#dark;" top="8"/>
  • 9.  RE: Hyperdeck Control in CCs
    Posted 01-25-2017 21:27
    Yeah, just shows up blank in Dashboard. Sorry. I tried a few variations to get it in and no luck.
  • 10.  RE: Hyperdeck Control in CCs
    Posted 01-25-2017 21:48
    If you saved it directly to a file, you'll need to add this to the very beginning.
    <?xml version="1.0" encoding="UTF-8"?>
  • 11.  RE: Hyperdeck Control in CCs
    Posted 01-25-2017 21:57
    Thanks! That worked right. Now, I just can't seem to get it to be triggered by the GPI on Custom Control. 7788 and RossTalk are enabled correctly. Do I need to point the script so it is controlled by the Dashboard software?
    Thanks for your awesome help.
  • 12.  RE: Hyperdeck Control in CCs
    Posted 01-25-2017 21:59
    I have already set up the buttons to be triggered by GPI 3 and GPI 4
    Do you happen to be running this on the same machine as XPression? We could try changing the port from 7788 to something else (perhaps 7789 or 7790)
  • 13.  RE: Hyperdeck Control in CCs
    Posted 01-25-2017 22:02
    xpression isn't running. Let me try a different number though. My screen shot of Custom Control was correct, right?
    I saw the 3/4 and adjusted CC
  • 14.  RE: Hyperdeck Control in CCs
    Posted 01-25-2017 22:03
    Shouldn't be a "TAKE" it should be a "GPI"
  • 15.  RE: Hyperdeck Control in CCs
    Posted 01-25-2017 22:04
    Sorry loaded wrong one.
  • 16.  RE: Hyperdeck Control in CCs
    Posted 01-25-2017 22:05
    Is IP when setting up xpression supposed to be computer IP?
  • 17.  RE: Hyperdeck Control in CCs
    Yes. As long as "xpression_1.0(1)-S1" is pointed at the IP address of the computer running DashBoard.
    Have you verified that pressing the record start/stop buttons manually works as you intend?
  • 18.  RE: Hyperdeck Control in CCs
    Posted 01-25-2017 22:06
    Is computer IP supposed to be what you setup Xpression with on carbonite?
  • 19.  RE: Hyperdeck Control in CCs
    Posted 01-25-2017 22:07
    The IP of the DashBoard computer.
  • 20.  RE: Hyperdeck Control in CCs
    Yes, it works great.
  • 21.  RE: Hyperdeck Control in CCs
    Posted 01-25-2017 22:09
    10.2.24.57
  • 22.  RE: Hyperdeck Control in CCs
    Posted 01-25-2017 22:11
    Should it be setup on carbonite in a slot number or SP?
  • 23.  RE: Hyperdeck Control in CCs
    Posted 01-25-2017 22:13
    Let's cut Carbonite out of the mix.
    Try adding this into your custom panel and see if it triggers the record (adjust the port as necessary):
    <button buttontype="push" height="132" left="14" name="TRIGGER RECORD GPI" top="13" width="243">
       <task tasktype="ogscript">rosstalk.sendMessage('10.2.24.57', 7788, 'GPI 3', null);
    </task>
    </button>
  • 24.  RE: Hyperdeck Control in CCs
    Posted 01-25-2017 22:17
    A new custom panel or in the record one? It does record like the other buttons within the .grid file.
  • 25.  RE: Hyperdeck Control in CCs
    Posted 01-25-2017 22:19
    The only thing not triggering is the custom control.
  • 26.  RE: Hyperdeck Control in CCs
    Posted 01-25-2017 22:20
    It can be in a new CustomPanel or inside of your current one (you can delete it when you're done). It is just firing the same command to DashBoard that the Carbonite should be.
    If it is properly triggering the record, then everything is set up correctly in DashBoard and your problem is in the configuration of your device or custom control on the Carbonite... if that turns out to the the case, technical support or the Carbonite forum should hopefully get that part straightened out for you.
  • 27.  RE: Hyperdeck Control in CCs
    Posted 01-25-2017 22:21
    Ok. Everything else fires fine, so not sure why. I'll post over there.
