Blackstorm - Hold, Cue, Pause default?
michael coppolino
michael coppolino03-27-2015 19:11
michael coppolino
michael coppolino03-27-2015 19:44
  • 1.  Blackstorm - Hold, Cue, Pause default?
    Posted 03-02-2015 18:35
    Is there a way to set the default end action in Dashboard to be hold, cue, pause when adding a clip to a list?
  • 2.  RE: Blackstorm - Hold, Cue, Pause default?
    Posted 03-02-2015 18:59
    Each BlackStorm Server DashBoard client computer contains a defaultSettings.xml file in the following folder:
    C:DashBoardworkspace.metadata.pluginscom.rossvideo.softmetal.riceconf
    Since DashBoard is a client side application, you must make setting changes to the defaultSettings.xml files on each DashBoard client computer connected to your BlackStorm Server.
    This file contains the following settings:
    defaultNewECAType:
    The default playlist End of Clip Action (ECA) to use when adding multiple clips to a playlist. Available values are xfade, vfade, vfadepause, next, pause, or holdcuepause.
    defaultNewECAParam:
    The default duration to apply to each ECA.
  • 3.  RE: Blackstorm - Hold, Cue, Pause default?
    Posted 03-03-2015 02:44
    That worked perfectly. Thank you!
  • 4.  RE: Blackstorm - Hold, Cue, Pause default?
    Posted 03-26-2015 20:32
    Garner and Aaron,
    I'm new to this forum and the Ross family. I have a Carbonite running with Dashboard with 2 channels of Blackstorm. I'm running software ver 10.0.2. Also trying to set default end action to Hold, cue, pause when adding clips to a playlist. However it appears we don't have that default settings xml file?
  • 5.  RE: Blackstorm - Hold, Cue, Pause default?
    Posted 03-26-2015 20:41
    I actually posted the file path in that post without slashes. Did you check here on your Dashboard PC:
  • 6.  RE: Blackstorm - Hold, Cue, Pause default?
    Posted 03-26-2015 20:42
    The path is:
    C:
    DashBoard
    Workspace
    .metadata
    .plugins
    conf
    defaultSettings.xml
    ...does that help?
  • 7.  RE: Blackstorm - Hold, Cue, Pause default?
    Posted 03-26-2015 20:43
    I did not know the forum removed backslashes...
    (Link to same image)
  • 8.  RE: Blackstorm - Hold, Cue, Pause default?
    Posted 03-27-2015 14:06
    Thanks for the quick reply. Followed the path to conf file folder and it appears that file does not exist on my system! Amy ideas how to proceed?
  • 9.  RE: Blackstorm - Hold, Cue, Pause default?
    Posted 03-27-2015 15:37
    Are you checking Dashboard software installed directly on the BlackStorm or a remote PC?
    Can you check the Dashboard folder that is directly on the BlackStorm and see if the file is there?
    (Note that modifying the file on the BlackStorm won't make the remote Dashboard work - just want to see if you have the file anywhere)
  • 10.  RE: Blackstorm - Hold, Cue, Pause default?
    Posted 03-27-2015 18:48
    I don't have the file on either the BS or the remote pc
  • 11.  RE: Blackstorm - Hold, Cue, Pause default?
    Posted 03-27-2015 18:50
    What version of BlackStorm are you running?
    Hover over the BlackStorm icon in Dashbaord to get the version.
    1.#.###
  • 12.  RE: Blackstorm - Hold, Cue, Pause default?
    Posted 03-27-2015 19:11
    server 1.3.0.75
  • 13.  RE: Blackstorm - Hold, Cue, Pause default?
    Posted 03-27-2015 19:26
    Is that folder just completely empty or not present?
  • 14.  RE: Blackstorm - Hold, Cue, Pause default?
    Posted 03-27-2015 19:44
    Not present
  • 15.  RE: Blackstorm - Hold, Cue, Pause default?
    Posted 03-27-2015 19:47
    Do you have the com.rossvideo.softmetal.rice folder?
  • 16.  RE: Blackstorm - Hold, Cue, Pause default?
    Posted 03-27-2015 19:51
    Yes! I have everything until I get to the default settings file....
  • 17.  RE: Blackstorm - Hold, Cue, Pause default?
    Posted 03-27-2015 20:10
    Can you do a Windows Search for the file? It HAS to be on the system somewhere.
