Hi Ryan,
While our switchers have created many different versions of their VDCP communications libraries to handle all of the variations in the different devices, the DashBoard implementation targeted only the interaction used for BlackStorm.
In terms of troubleshooting, if the VirtualVTR does not support channels, what are you supplying as a channel? Have you tried 0?
If you are able to capture the TCP/IP traffic going to/from the VirtualVTR through something like Wireshark, it might be helpful to compare the differences between the messages coming from the switcher to control the VTR vs. the messages from DashBoard.
Or, if the virtual VTR has a log of the messages it has received and any issues, that might provide you more information (I know BlackStorms do this).
James
