  • 1.  RossTalk Command for MiniME Bus
    Posted 07-05-2015 17:13
    Using the RossTalk command: XPT bus:source,
    Is it possible to select the MiniME bus? The only options I see are:
    • AUX:aux bus number
    • MLE:MLE number : PGM
    • MLE:MLE number : PST
    • MLE:MLE number : KEY:keyer number
  • 2.  RE: RossTalk Command for MiniME Bus
    Posted 07-05-2015 18:49
    Hi Shane,
    The following link has a pdf listing the commands for Rosstalk:
    http://www.rossvideo.com/pdf/cutsheets/vision-interface/cg/RossTalk-Commands(4802DR-403-06).pdf
    In it, it shows that you can use 'MME' to address the MiniMe areas.
    If you have any issues getting that to work let us know.
    Troy.
  • 3.  RE: RossTalk Command for MiniME Bus
    Posted 07-05-2015 19:29
    Awesome!! Thanks, that is perfect.
    I was looking at a different PDF
    http://www.rossvideo.com/pdf/cutsheets/carbonite-interface/RossTalk-Commands(4802DR-403-04).pdf
    (Kinda confusing what PDF to look at. Is there an index of the most recent PDF documentations? I"ve had a hard time finding the right documents on this site.)
  • 4.  RE: RossTalk Command for MiniME Bus
    Posted 07-05-2015 23:11
    The best we have right now is the search feature in the upper right of the website.
    I'm glad the document gave you what you needed.
    Troy.
  • 5.  RE: RossTalk Command for MiniME Bus
    Posted 07-06-2015 15:37
    I need a little more help on this. The PDF you provided has different commands than the PDF I was using.
    for example: MLEAUTO vs MEAUTO
    On the dashbaord, my RossTalk application has MLEAUTO, not MEAUTO. And, the commands as listed in your PDF do not work for me.
    Is this because of a different version of the Dashboard, or a different firmware of the Carbonite frame?
    I am running Dashboard ver 6.2.5
    Carbonite Frame ver 9.1.0.11223
  • 6.  RE: RossTalk Command for MiniME Bus
    Posted 07-09-2015 13:05
    Hi Shane,
    Carbonite will accept either MEAUTO or MLEAUTO, they will do the same thing. There is a newer version of Carbonite available (10.1.0), although these functions should work fine in the version you have. When creating the RossTalk task in Dashboard I suggest you choose "Custom" and then type the entire command in. For example:
    MLEAUTO MLE:1
    That should run an autotrans action on ME 1. Let me know if that works for you.
    Gary
  • 7.  RE: RossTalk Command for MiniME Bus
    Posted 07-10-2015 03:34
    >>MLEAUTO MLE:1
    Yes, but my question is for applying the command to the mME bus.... Anyway, after calling Ross Support and working through through this, I discovered that both PDF's (above) are incomplete.
    This works for ME1 BUS:
    XPT ME:1:PST:IN:1
    MEAUTO ME:1
    This works for MME1 BUS:
    XPT MME:1:PST:IN:1
    MEAUTO MME:1
    Poor & confusing documentation. Neither document defines MEAUTO MME:1, one has the MLEAUTO command, the other MEAUTIO command, and MME:1 does not work with MLEAUTIO and MME:1 is not defined as an option for the MEAUTO command..
    I'd love it if you could remove the older documents and replace with a current & more complete revision. With different revsions floating around, It's frustrating when you can't find the most recent and get the commands to work.
  • 8.  RE: RossTalk Command for MiniME Bus
    Posted 07-10-2015 13:21
    Thanks for the feedback on the documentation Shane,
    It has been passed along to the Switcher team.
