  • 1.  Toggle / Radio Button Orientation
    Posted 03-23-2017 18:55
    Seems like a silly question, but how can I make the radio buttons/toggle buttons orient vertically instead of horizontally? What menu option am I missing?
    thanks!
    Brian
  • 2.  RE: Toggle / Radio Button Orientation
    Posted 03-23-2017 19:06
    Well, it appears checking the "Keep returned elements together" box changes the orientation. Not what I was expecting it to do. This seems to only work for radio buttons though, but not toggle buttons.
  • 3.  RE: Toggle / Radio Button Orientation
    Posted 03-23-2017 20:41
    You can get full control over how many radio items appear for a parameter and in how many columns (either by having all in a row horizontally, or all in a column vertically, or having a grid of them, ie. two columns with three choices in each etc..).
    To do this:
    1: Create a table on your custom panel.
    Leave it as the default of 1 row and 1 column.
    2: In the same UI select the 'Override Default' checkbox for 'Max Elements per row'.
    Whatever number you put here will be how many column you have, so, if you want everything in 1 column vertically, put 1 here.
    3: Add your parameter to the cell in your table.
    (Remember that you created this table with only 1 cell, you DID not in step 2, change how how many cells you had).
    When you add the parameter, make sure the checkbox for 'Extract Individual Controls' is selected.
    You now have a UI element in a Custom panel that you can drag around, resize, etc.. and is completely configurable for how many columns and rows you want to display your radio buttons for.
    Let me know if this gives you what you need!
    Troy.
  • 4.  RE: Toggle / Radio Button Orientation
    Posted 03-23-2017 21:12
    Thanks Troy, I'll check it out.
