  • 1.  Changing individual button colors.
    Posted 08-26-2015 16:11
    Hello!
    I am very new to the video switching world but I'm eager to learn all I can. I have been fiddling around with the Carbonite 2me and I figured out how to change the color of the whole board at once but i can't for the life of me find out how to change certain parts of the board. I have seen plenty of people online that have the top half one color and the bottom half another. How do I do this? Preferably through the built in UI since I don't have access to Dashboard at the moment. Thank you!
  • 2.  RE: Changing individual button colors.
    Posted 08-28-2015 14:06
    Hello Jack!
    In the MENU -> USER -> SCHEME -> NEXT menu, you have the ability to load premade color schemes which will give each ME row it's own color.
    The scheme menu also allows you to create your own color scheme for the panel. At this time, when creating your own color scheme, it makes all rows on the panel the same color.
    Hope this helps!
    -Mike
  • 3.  RE: Changing individual button colors.
    Posted 09-01-2015 17:01
    Thank you for the response! How exactly do you create an ME color scheme? Is it possible through dashboard?
  • 4.  RE: Changing individual button colors.
    Posted 09-01-2015 17:06
    Hey Jack,
    The scheme menus are not in Dashboard. You'll have to change the colors of the panel from the panel menu.
    MENU - USER - SCHEME
    Once you change your Hue/Sat/Lum levels, you can hit NEXT twice to get to the Save part of the menu. There are four custom spots in which to save your color scheme.
    Again, custom schemes do not allow you to create individual button or row colors.
    Let me know if this works out for you.
    -Mike
  • 5.  RE: Changing individual button colors.
    Posted 09-01-2015 17:41
    Thank you for the swift reply! If you don't mind me asking, how is it that I see other people change the color of an ME? Some people have certain rows certain colors. If it isn't possible on my machine, that is fine. Thank you for your help regardless.
  • 6.  RE: Changing individual button colors.
    Posted 09-01-2015 17:45
    It's entirely possible that what you're looking at is one of the pre-made schemes that we provide in the Carbonite. Some of those schemes have colors for each MLE row. You can find these under:
    MENU - USER - SCHEME - NEXT, which should get you to the "load" menu. Scroll through and check them out.
    -Mike
