  • 1.  DashBoard Server
    Posted 10-05-2017 14:01
    I'm not fully clear about what is possible with the server:
    I unterdstood that it is possible to define user-rights.
    But following questions are still open:
    1) Where is running the logic or the ogScript? - On the server or on the client?
    2) Does all clients loggin-in at the same computer, or can several computers / clients work at the same time with one server?
    Thanks a lot
    Martin
  • 2.  RE: DashBoard Server
    Posted 10-05-2017 15:08
    Hi Martin.
    DashBoard's User Rights Management Server simply holds the rights for each user.
    Any number of DashBoard client PCs can access the server at the same time - they connect and use it to verify their permissions for openGear Frames and devices they are trying to talk to.
    All ogScript calls, device information, and parameter updates still flow through the DashBoard Client PCs. The server is just used to store permissions.
    James
  • 3.  RE: DashBoard Server
    Posted 10-05-2017 15:10
    Great, thanks for the fast support!
