  • 1.  Dashboard exercise for the day: Use dashboard to trigger scene director of scene that is on line
    Posted 12-15-2017 20:51
    We have a "mistletoe cam" coming up (aka kiss cam) I want the operator of our xpression to be able to click a button on dashboard that will play an animation to make the hanging mistletoe wiggle at his command. I know how to do this using keystroke macros but I would like to design it on dashboard just for the education. Can someone get me started down the right road?
  • 2.  RE: Dashboard exercise for the day: Use dashboard to trigger scene director of scene that is on line
    Posted 12-15-2017 21:02
    The easiest way would be to go into XPression's Keyboard/GPI Mapping and, at the same action you would use to assign a keyboard shortcut, also edit the GPI assignment to add a RossTalk/SmartGPI number. You would also add a RossTalk/SmartGPI port under Hardware Setup -> GPI Boards.
    You can then use the "GPI" command in Visual Logic to send the GPI number you assigned to the XPression.
    James
  • 3.  RE: Dashboard exercise for the day: Use dashboard to trigger scene director of scene that is on line
    Posted 12-15-2017 21:17
    Thanks James. I find myself falling back on knowledge I already have and not pushing forward.
  • 4.  RE: Dashboard exercise for the day: Use dashboard to trigger scene director of scene that is on line
    Posted 12-15-2017 22:04
    Wow, that was easy the way you explained it. Thank you James.
  • 5.  RE: Dashboard exercise for the day: Use dashboard to trigger scene director of scene that is on line
    Posted 12-15-2017 22:06
    We do try to make it that way when possible :)
    Glad it worked out for you.
    James
