Hi Shane,
I'm assuming that you already have the regular plugins for BlackStorm in DashBoard running and that you are looking at making a custom panel that has some Buttons to control them.
Adding BlackStorm commands is pretty easy.
After you have added a button to a Custom panel, you need to add a 'Task' to it.
When you open the Task window you will see one of the options is for VDCP, those VDCP commands are the ones that will control BlackStorm.
If you are having trouble finding this take a look at the videos at DashBoardU that show how to add tasks to buttons:
http://www.rossvideo.com/control-systems/dashboard/dashboard-u/index.html
Most everything is pretty straightforward, querying BlackStorm for it's video clips and displaying those is a bit trickier but we do have an example panel posted on the website here:
http://www.rossvideo.com/control-systems/dashboard/dashboard-u/video-tutorial-108.html
Let us know if this doesn't answer your questions.
Troy
