  • 1.  Wrapping Text
    Posted 09-21-2018 22:03
    This might be an easy answer. But can you wrap text on a Dashboard Button and if so how do you do it?
    Ryan
  • 2.  RE: Wrapping Text
    Posted 09-21-2018 22:17
    I've found it wraps nicely if you surround the button text with html tags.
    <html>button text</html>
  • 3.  RE: Wrapping Text
    Posted 09-24-2018 12:31
    For a simple linebreak you can use \n (newline).
    Not only will this give you the linebreak, but when you then close the edit window and re-open it at a later time, it will wrap the text with the above mentioned -tags and a at the linebreak. :)
  • 4.  RE: Wrapping Text
    Posted 09-30-2018 23:33
    This is great thank you so much!
