Here is an example that ties a numeric parameter to the XPresssion take command:
<abs contexttype="opengear">
<meta>
<lookup id="hosts">
<entry key="XPression.scriptport">false</entry>
<entry key="XPression.color">-1145302</entry>
<entry key="XPression.port">7788</entry>
<entry key="XPression.host">params.getValue('XPression_IPAddress', 0)</entry>
<entry key="XPression.scripthost">true</entry>
<entry key="XPression.devicetype">XPression</entry>
</lookup>
<params>
<param access="1" constraint="0.0;100000.0;0.0;100000.0;1" constrainttype="INT_STEP_RANGE" name="Take ID" oid="Take_ID" precision="0" type="INT32" value="0" widget="spinner"/>
<param access="1" maxlength="0" name="XPression_IPAddress" oid="XPression_IPAddress" type="STRING" value="192.168.1.150" widget="default"/>
</params>
</meta>
<param expand="true" height="57" left="19" oid="Take_ID" top="17" width="207"/>
<button buttontype="push" height="64" left="234" name="Take" style="bg#FA0505;" top="16" width="194">
<task tasktype="ogscript">
/*! block id=1037,1038 !*/
rosstalk.sendMessage(params.getValue('XPression_IPAddress', 0), parseInt(ogscript.getPrivateString('hosts', 'XPression.port')), "TAKE " + params.getValue('Take_ID', 0) + ":" + (1 -1) + ":" + 1);
<block id="1037" type="XPression_xpression_take" x="292" y="22" w="243" color="#ee862a" TAKEID="ID:1038" BUFFER="1" LAYER="1" />
<block id="1038" type="param_Take ID (Take_ID)[0]" x="18" y="24" w="243" SET="" />
/*!!<checksum>bbb099390c8844a363985161320221d3</checksum>!!*/</task>
</button>
<label height="51" left="21" name="XPression IP: " style="txt-align:east" top="104" width="112"/>
<param expand="true" height="59" left="136" oid="XPression_IPAddress" top="102" width="292"/>
</abs>#DashBoard
