Absolutley!
When you set up your tasks, in visual logic, there's this little green pluss sign next to Devices and Parameters.
If you click that, and then "Add Carbonite", insert the correct IP and Port, and you'll get this little folder there for your Carbonite containing all the RossTalk commands you can easilly send to your Carbonite. Basically making you set up a bunch of commands to the Carbonite simply by one button :)
Have fun!
