Hi Josh,
This is easily accomplished in DashBoard.
You will want to make a 3rd parameter, let's call it 'distance' for the sake of argument.
This 3rd parameter will be the one you DataLinq to XPression.
You need to put a task on each of the 2 other parameters. When you put a task on a parameter, it is run whenever that parameters value changes.
On each of those tasks you will want to update the 3rd parameter.
The task will be pretty small and look something like:
//Get the values of the 2 parameters and put them into local variables
var downs;
var yards;
var distance;
downs = params.getValue('params.downs',0);
yards = params.getValue('params.yards',0);
distance = downs + ' ' + yards; // the extra quote in the middle is to add a space between your two pieces of text
// set the 3rd parameter now
params.setValue('params.distance',0,distance);
Of course, your variable names, parameter names, exact formatting of how you want your 3rd parameter to include information from your yards and downs parameters will be slightly different.
// you might have wanted something like
distance = downs + ' Down: ' + yards + 'Yards';
Which would output text that looked like "3rd Down: 7 Yards" assuming that your downs variable included text options for '1st', '2nd','3rd' etc.. (notice the difference between putting quotes around text to be used exactly and using a variable name).
