  • 1.  Free Hockey Scoreboard grid file (also posted in xpression forum, sorry for the double post!)
    Posted 12-05-2014 16:27
    Hi Everyone,
    I'm working on building a hockey score interface in Dashboard for use with Xpressions, and I just wanted to share it with everyone.
    http://captaingraphics.net/download/hockey-scoreboard-dashboard-grid/
    Update: Video demo showing the capabilities of this grid file: https://vimeo.com/120733738
    Now this file is free for you to use and modify, however I make no guarantees! Consider it a learning tool to see how DashBoard Can be used with Xpression in a sports setting.
    It's still a work in progress, and I'm letting you know that I am in no way a coding expert. So a lot of the code is quite clunky, specifically on the penalty timers, and the "populate dropdowns" button. If there are any JavaScript wizards out there, please feel free to work your magic.
    Some features:
    - The usual timer, score, shots on goal, team names, etc.
    - Also includes ability to add penalties: will automatically calculate if it's a powerplay, 4 on 3, 5 on 3, etc. (Thanks to James Peltzer [URL="http://community.rossvideo.com/members/jamespeltzer/"][URL="http://community.rossvideo.com/members/jamespeltzer/"]@jamespeltzer[/URL][/URL] for his help with these!)
    - Ability to enter team rosters and then select the names from a drop-down, so you can get that lower third up quickly. (Big thanks to Troy English [URL="http://community.rossvideo.com/members/troyenglish/"][URL="http://community.rossvideo.com/members/troyenglish/"]@troyenglish[/URL][/URL] over on the DashBoard forum for his help on that one!)
    Known Issues
    Some issues that I'm not sure how to fix. Any help is appreciated:
    - Penalty labels may not change until timer starts running
    - Dropdowns will not populate unless players, coaches, and goalies tables have been modified (at least 1 from each)
    - Dropdowns may not populate Datalinq right away, you'll have to select another name first
    Once again, This is still very much a work in progress. I'm not offering any support for this file, but am open to any feedback. This file is being given out with the assumption that you will have at least a basic knowledge of DashBoard, Xpression, and Datalinq. If you need to get caught up on any of those, check out DashBoard U, and Xpression U. (There are also a lot of good Datalinq videos here: http://xpression.rossvideo.com/videos/)
    Please feel free to share any revised versions here, I'm hoping that together we can come up with something really useful!
  • 2.  RE: Free Hockey Scoreboard grid file (also posted in xpression forum, sorry for the double post!)
    Posted 12-11-2014 12:14
    Bamboo,
    I like the roster part of this. But I cant seem to find the datalink in Xpression to fill the text fields.
    thanks
    john
  • 3.  RE: Free Hockey Scoreboard grid file (also posted in xpression forum, sorry for the double post!)
    Posted 12-11-2014 19:32
    Okay, that was a easy fix no problem.
    but now when I use the datalink in Xpression, I would have thought I used the Value of Away Player name 0. and any time I change the roster it would gear the new player name. but It does not change. Should I be using a different value?
    many thanks!
  • 4.  RE: Free Hockey Scoreboard grid file (also posted in xpression forum, sorry for the double post!)
    Posted 12-12-2014 19:56
    Hi John,
    The datalinq values you should be using for the player names:
    Home.Numberdropdown
    Home.PlayerDropdown
    Home.PosDropdown
    Same for away. Hope that helps!
